Author Topic: oil pressure  (Read 1795 times)
Veedubgt18v
oil pressure
« on: 31 January 2004, 19:17 »
what should the oil pressure gauge say when it is working? cos it sort of fluctuates depending on engine speed/load etc. is this normal?
when im driving along it says 4.5bar and when idling it says 2bar.
Offline mk1
Re:oil pressure
« Reply #1 on: 31 January 2004, 19:42 »
Sounds ok, 4.5 bar is over 65psi. At idle when the engine is hot, 2 bar is good oil pressure.
Steve.
golfvr6
Re:oil pressure
« Reply #2 on: 01 February 2004, 00:52 »
I hope the oil pressure does increase when you rev it or you are f**ked
 :D
Offline modulater
Re:oil pressure
« Reply #3 on: 01 February 2004, 11:03 »
sounds like its running fine to me.
Veedubgt18v
Re:oil pressure
« Reply #4 on: 01 February 2004, 13:50 »
cool!  ;D
turbo
Re:oil pressure
« Reply #5 on: 05 February 2004, 04:17 »
minimum 2 bar at 2000 rpm which oils 80c!
your oil pressure is good then......in fact thats great...
« Last Edit: 05 February 2004, 04:18 by vwsystems »
