Author Topic: HOW to... 16v (KR) Ignition timing  (Read 14546 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 28 March 2007, 18:42 »
This is basically what I done to time my valver!
  • Engine up to operating temp (fan kicks in, oil temp above 800C
  • Switch off.
  • Unscrew green plug on top of gearbox.
  • Mark your 6BTDC with tippex make it easier to see! You may need to turn engine so that you can see your marks. I put it into fourth gear and pushed or pulled car slowly until I could see the marks!
  • Disconnect red connector at coil.
  • Loosen dizzy bolts, so that it moves but not so that it spins!
  • Connect timing light as per instructions.
  • Start engine.
  • Point timing light into the gearbox "hole".
  • you should see the marks - if you're timing is anywhere near!
  • Move the dizzy until you can see the marks.
  • Carefully adjust the dizzy until you get the big 6BTDC mark lined up with the mark on the gearbox housing.
  • Swith off.
  • Tighten Dizzy Bolts.
  • Have a final check if you want!
  • Re-connect red lead under coil.
  • Take it for a spin!!!
I had to adjust the idle slightly while seeting the timing.
You will probably now need to check the CO setting.
