Author Topic: Fuel Fillup light.  (Read 4679 times)
Offline Creepy Coupe
Fuel Fillup light.
« on: 28 March 2007, 12:49 »
I was always under the impression the R32 had a 55 ltr tank, however after reading a suppliment that came with the handbook pack, it states 60 ltrs.
So today with only 25 miles left on the fuel trange display I was surprised the little fuel pump light didn't illuminmate. even after driving for 10 miles with 25 miles left dispayed, it still didn't light up.
I wondered if VW had fitted a bigger fuel tank, but had forgetten to inform the on board computer.
As I'd imagine the little fuel pump light works off of the float level and not what the OBC says.
« Last Edit: 28 March 2007, 13:38 by Creepy Coupe »
Offline Hully
  • GTI Edition 30, Reflex Silver - May 07
Re: Fuel Fillup light.
« Reply #1 on: 28 March 2007, 12:55 »
I seem to remember from the Gti and Ed30 that I drove the fuel light came on around the 25-30 miles range to go.  Hmmm, seems strange, even if you have a bigger tank that the light still wasn't on at 25 to go.  Did you fill up then, or push on untill the warning came on?  If you did the former could it be that the alert refuel isn't working on your MFD?  Is it a highline or midline MFD?
MkIV GTI PD150 sold, now FOR SALE MkV GTI Ed30, Reflex Silver, 07, manual, 5 Dr, 29.5k miles, 1 owner from new, xenons, cruise, park sensors, ugraded VW stereo and sound system, MFSW, Armrest, sunroof, immaculate never raced or thrashed, totally original, For Sale - PM me for details.
« Reply #2 on: 28 March 2007, 13:09 »
I didn't fill up, and will try to get closer to home tonight, :undecided: light comes on when the ignition is switched on,if that means anything, and it's a highline comp.
Offline micalee
« Reply #3 on: 28 March 2007, 13:14 »
I have had a big orange fuel pump sign come up on mine telling me i have to refuel - its just as annoying as the windscreen water level light!
Cant remember at what point (in miles) it comes on though
MK5 R32 DSG 2006 For Sale soon
« Reply #4 on: 28 March 2007, 13:18 »
Yes I have the same, except it hasn't come on yet, well only when I first switch the ignition on.
Offline wantmygti
« Reply #5 on: 28 March 2007, 13:58 »
Mine (GTi) comes on at 30 miles but i struggle to actually get 30 miles out of it. Partly as it keeps flashing up every minute and it's gets filled up just to shut it up.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline Hully
« Reply #6 on: 28 March 2007, 14:04 »
Do you have a fuel can with you in the boot?  :wink: You might need it.  Seriously though, when you say it comes on when you turn the ignition on, does that also happen when the tank is full, or does it only come on now, with the tank nearly empty?
« Reply #7 on: 28 March 2007, 14:18 »
Yes I think it would come on for the few seconds it does, regardless of quantity, except of course if it WERE empty.
Working out the tank range, based on 25 mpg and leaving half a gallon in and a 55 ltr tank I should be able to cover 290 miles, and I've covered 296 so far.
Offline AlanH
« Reply #8 on: 28 March 2007, 16:49 »
Mine comes on at 40 miles every time.
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline wantmygti
« Reply #9 on: 28 March 2007, 16:53 »
How strange!! Definately at 30 miles it goes bong and the big fuel pump sign appears intermittently.
