Author Topic: 2ltr bottom end  (Read 2011 times)
Offline jonesy
2ltr bottom end
« on: 31 January 2004, 14:25 »
does any one know wot is the best 2ltr bottom end to use in a mrk2 16v ,i was thinking of getting a corrado  bottom end and fitting new piston rings,also will it bolt straight in and will i be able to use my 16v head,..cheers for any replys..... :-\
Blue MK2
Re:2ltr bottom end
« Reply #1 on: 31 January 2004, 15:28 »
mk3 16v ???, dunno
Offline modulater
Re:2ltr bottom end
« Reply #2 on: 31 January 2004, 17:22 »
The 9A is the best one to use as it is the same height as your current KR and you wont have problems.
The KR head can bolt straight on. If you do keep the 9A head on it make sure you swap the cams as the 9A cams are very mild compared to the KR ones.
Offline mk1
Re:2ltr bottom end
« Reply #3 on: 31 January 2004, 18:03 »
Modulater is bang on, use the 9A block with your head. Use the 9A head gasket and your clutch-flywheel will bolt straight up to the crank.
Steve.
Offline jonesy
Re:2ltr bottom end
« Reply #4 on: 31 January 2004, 20:21 »
thks for your advice lads,i take it the 9a is a corrado engine,is the number stamped on the block anywhere,as i will be searching the scrapyards ......ive got a couple of   fast road kentcams to put in the head,or do you think i should stick with the kr cams....i know the kentcams wont give as much torque but 2lt should compensate for this i think any1 done this conversion
Offline mk1
Re:2ltr bottom end
« Reply #5 on: 31 January 2004, 22:47 »
9A is also found in the Passat,
cheaper than a Corrado and same engine ;).
Code is on the timing belt cover or in the boot on a sticker.
Good engine ;).
Can't say about cams.
golfvr6
Re:2ltr bottom end
« Reply #6 on: 01 February 2004, 00:49 »
Stick with the KR inlet cam, as the 9A one is cat friendly.
Offline modulater
Re:2ltr bottom end
« Reply #7 on: 01 February 2004, 11:27 »
I would run it with the KR cams for a while, then swap to the kent fast road cams and see which driving style you like best.
You can always swap them back.
