Author Topic: phil88 - mk2 16v  (Read 51463 times)
Offline phil88
Re: phil88 - mk2 16v
« Reply #10 on: 02 April 2007, 21:28 »
did some work on my car today, got the dash out, was a bit of a pain cause the previous has installed a immobilser and just used tape to stick the wires together. had to cut all the wires out and connect them back up again.
also sorted my door out, applyed some more filler and then applied primer, as come out well, but will need a good sanding down.
Offline phil88
« Reply #11 on: 06 April 2007, 22:31 »
done a bit more work on my car
hammerite primer was a bit thick for the doors and had come out like a ploughed field so ive had to rub it all down
going to get some different primer from somewhere else.
also before i tackle any more rust people have been suggesting getting some POR15 to stop the rust coming back. the stuff looks really effective so thats a job for summer
so, probably lowest on my list of prioritys i decided to smooth the rear badge over
i ground back just the bits i needed to tack the plate in place
tacked in place
ground the welds back then, smoothed over
sanded down
thats it so far, think im gonna have a full day on my car tomorrow
« Last Edit: 06 April 2007, 22:32 by phil88 »
Offline phil88
« Reply #12 on: 09 April 2007, 14:29 »
didnt end up doing that much
there was a bit of bubbling near the window so ive ground all the rust back and filled them
im back at uni tomorrow so that will be it for 10 weeks
Offline phil88
« Reply #13 on: 18 June 2007, 17:54 »
hello again,  back from uni and got 4 months off (plenty of time to play with my car  :grin:) got the car out today and took the windscreen out not suprised that there was rust underneath it. but then it started to rain, so went back inside.  :rolleyes:
mhh, rust didnt seem that bad, maybe its the camera  :huh:
Offline phil88
« Reply #14 on: 18 June 2007, 21:26 »
i got bored inside so went and took the wings off
first side off
new brakes me thinks and lots of hammerite
finding the stupid bolt
other side off
not looking much like a golf anymore
Offline phil88
« Reply #15 on: 19 June 2007, 19:17 »
did a little bit more today
have been thiniking about taking the engine out, but i dont have a m8 spine bit, so that will have to wait a bit. So i took the backbox off, it havd a massive hole in it so wasnt going to keep it.
put it on some blocks
the remains of the backbox
trying to remove the heating system, having a few problems, dunno whats holding it in!
Offline phil88
« Reply #16 on: 20 June 2007, 17:24 »
primed up the lower front panel today
got the wire brush thing on the drill and got rid of all the rust
then primer on it
im still using the thick stuff so a rub down will get it all smooth  :smiley:
I cut the rust out of the windscreen surround, still some little bits, but gonna give it a scrub, and i have some por-15 in the post
welded the window seal holder in,  looks a bit like rust but just need a polish, then it started raining half way though so had to back under cover  :rolleyes:
Offline phil88
« Reply #17 on: 22 June 2007, 18:00 »
little bit of an update
painted the bottom frame, its good to see something looking finished, put it up to the car and looked really good  :smiley:
my POR-15 starter kit came though
used some of the acid etch that came with the kit, and its got rid of all the rust, really impressed
just before welding it all up
typical british weather it started raining again so its all to be ground down another day
Offline phil88
« Reply #18 on: 23 June 2007, 20:38 »
cleaned up the welding today and then added filler, one area of rust sorted, only another hundred or so to go  :laugh:
had enough of the windscreen area for a bit so moved onto a sill, cut all this crap out, eek
and then ive started to fabricate the replacement, still needs a few little adjustments but its on the way
bought a replacement panel for the rear lower panel off ebay, bargin for £7
Offline phil88
« Reply #19 on: 27 June 2007, 22:21 »
been abit busy, still waiting on the rear panel from ebay, also ordered a replacement rear arch from hadrians, going to pick that up tomorrow. in the mean time ive been looking and more rust on my shell, ive welded the panel into the sill, painted it with por15 and im going to fill it soon, also today i had a look at the other side of the windscreen, was worse than i thought (as usual then) the must have been some damage to the car in its life, all my worse rust is in that area, and has just been covered up with buckets of filler, so been busy cutting all that out today.
patch welded in, the bottom bit was so awakward to weld
cut out all the rust, (there was loads)
first bit of the replacement welded in, getting the hang of this welding malarky
hopfully ill have some pictures of new panels tomorrow  :shocked:
