Author Topic: diagnostic port? and engine cuts out. 8v 2.0  (Read 1206 times)
Offline Mr Blue
« on: 27 March 2007, 17:24 »
hi people
I did a search but i still dont know where the dignostic port is on a mk3 golf 2.0 8v (m reg)
The car cuts out and read that its the ignition relay. I dont have a number '30' relay so what polistion should the '30' relay be? e.g. Top right 3rd one in??
chers
Blue :smiley:
Offline adyh
Re: diagnostic port? and engine cuts out. 8v 2.0
« Reply #1 on: 27 March 2007, 17:35 »
Totally remove the ashtray from the dash board . Now there is a piece of black plastic above the cigarette lighter , this slides to the right .
Offline Mr Blue
« Reply #2 on: 27 March 2007, 19:04 »
chers mate :smiley:
Ive found the relay. its right at the top and hard to see :evil:. Car runs when I tape relay so its deffo that
bsting
« Reply #3 on: 27 March 2007, 19:59 »
There are two white hooks on either side of the fuse/relay box
Flip those up and gently pull the thing down, this will give you better access.
Dont bother with the old #30 relay
Replace it with a new 'made in germany' one
Not online much m8 but Len405 will know what im on about  :smiley:
Offline Mr Blue
« Reply #4 on: 29 March 2007, 15:50 »
ok changed the relay for a brand new one
engine fired and then cut out again. not happy :angry: :angry:
I did look at the crank sensor?? the one thats got the connector on top of the engoine mount. The wires are almost bare and brittle.
I did unplug this when i got the engine to run and it cut off (just a test)
how much are these fookin sh!tty things?
Offline badboygolf
« Reply #5 on: 29 March 2007, 17:18 »
does the engine cut out while your driving? it used to happen to my golf so i replaced the engine. does your revs go up and down when the engines cold?
Offline adyh
« Reply #6 on: 29 March 2007, 17:19 »
A little bit drastic .
Offline Mr Blue
« Reply #7 on: 29 March 2007, 19:24 »
chers for the advice peeps
It was the damn sensor behind the engine mount! cost me about £115 on a trade account. still bloddy pricey and the only reason why im pissed off :angry: :grin:
Was awkward to fit as the engine mount had to be removed :angry:
Fired up and im going for a run. If it cuts out im burning the bastud :smiley:
