Need help on what ignition timing marks to look for on my 91 8v digi. Just had the engine apart to replace the rings and then went to set it up. The Haynes is as clear as mud, so I set the timing to what I thought were the ignition timing marks, a ´0´ on the flywheel, which I assumed was TDC, and a groove before it, which I assumed was the timing mark. But the engine ran horribly.
Hunting idle, mis firing, the works. So I retarded it by sound and got it running a whole lot better, but I want it right.
BTW, what is the timing angle BTDC?
