Author Topic: bad vibrations  (Read 1251 times)
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
bad vibrations
« on: 25 March 2007, 12:15 »
when i start my gti 8v i can feel it shake the steering wheel/column, then once its ticking over i can feel vibrations through the steering wheel.
i recently changed the front engine mount but it made no difference.
what else could it be?
Offline VapourTrails
Re: bad vibrations
« Reply #1 on: 25 March 2007, 12:44 »
is it powersteering?
what happens when your driving say regular town driving and motorway driving?
Offline jase555
Re: bad vibrations
« Reply #2 on: 25 March 2007, 16:12 »
yeh, tiz power steering, thought all mk3 gti's are? oh well. :laugh:
driving normal and motorway driving is ok. no vibs then. just on start up and tick over.
Offline EvilScotsman
Re: bad vibrations
« Reply #3 on: 25 March 2007, 16:32 »
loose pump mounts or pulley?
when you speed up it would balance out
"Handheld OBDII Scanner"
Offline jase555
Re: bad vibrations
« Reply #4 on: 25 March 2007, 17:43 »
you think?
ok will check that out. do you think it might be the rear engine mount or the gear box mount? would it be worth changing them?
Offline tommk3cab
Re: bad vibrations
« Reply #5 on: 25 March 2007, 18:36 »
if your up for it why not! it cant hurt! unless your paying someone! then it can!
Offline jase555
Re: bad vibrations
« Reply #6 on: 25 March 2007, 19:20 »
na, usually do the work meself.
Offline jase555
Re: bad vibrations
« Reply #7 on: 25 March 2007, 19:59 »
is the rear engine mount on the mk3 gti the same as the front on cuz they dont list it on euro car parts???
