Author Topic: Flat battery after giving a jump start  (Read 1662 times)
Offline patch900
« on: 24 March 2007, 16:13 »
My neighbours car had a flat battery the other day and I gave him a jump start. Couldnt really say no.
Not drove the car for a day or 2 and got in and the battery was totally flat ! Is this a coincidence or have I done something ? The battery has always been OK before this.
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline EvilScotsman
Re: Flat battery after giving a jump start
« Reply #1 on: 25 March 2007, 00:08 »
nah thats happened to me mate. It sucks but a dead battery can drain the life out of a good one. Your alternator or battery maybe are past it as well.
Deposits build on the plates and reduce the capacity over time. Try BAT-AID tablets £4 from an accesory shop, 2 tabs each cell then recharge wi a charger and should be good if the battery isnt knacked. Charging voltage from a good alternator is about 14v and when cranking the engine, the battery musnt drop below 10v. Less shows a weak battery.
"Handheld OBDII Scanner"
Offline patch900
« Reply #2 on: 25 March 2007, 18:28 »
Cheers evil, it started today but not easily.
Think the battery has had it, will have the alternator checked out as well. Do you know much an alternator is ?
Offline tommk3cab
« Reply #3 on: 25 March 2007, 18:34 »
depends if its from a scrappy or not, can usually get them reconditioned anyway, but new, ouch!
Offline patch900
« Reply #4 on: 25 March 2007, 19:10 »
cheers tom, will have it checked first. Fingers crossed its just the battery
Offline chrutchy
« Reply #5 on: 26 March 2007, 19:32 »
new high power alternator from euro car parts is bout 120 quid
not as much as people think
Offline monzablue16v
« Reply #6 on: 26 March 2007, 19:53 »
You can get them rebuilt for about £30 though :D
« Reply #7 on: 27 March 2007, 21:06 »
get a reconned exchange one, its quite cheap. As said, around £30 to £40 with your old one returned.
If you go to a breakers, a passat one will do as well if its exactly the same engine.
Offline patch900
« Reply #8 on: 27 March 2007, 21:08 »
Cheers mate, will change the battery first and see how I go. If it still acts up get the alternator changed.
Wished I had said no to the jump start but if someone asks you cant really say no.
« Reply #9 on: 27 March 2007, 23:32 »
well at least its shown up a weakness in the car before you got stranded somewhere.
Kwiksh!t will do an electronic battery and starting / charging current test for free by the way if you just roll up and ask.
If you give a jump start you should always have the donor car running so the alternator gives charge to both batteries then start the other car after 5 mins of running so its easy on the donor battery.
