Author Topic: smoke through airvents  (Read 3920 times)
Offline jasonpi
« on: 30 January 2004, 16:32 »
maybe ive never noticed it before but since i took the dash out a couple of weeks ago ive noticed smoke coming through the air vents any ideas
kniterider
Re:smoke through airvents
« Reply #1 on: 30 January 2004, 16:47 »
sounds a strange one that, but when i was sat in my mk2 the other night at work with the engine running i could have swarn i saw a mist coming out of my vents!!!, i put it down to either steam from the exhaust getting sucked in by the fan then blown into cabin or steam from the melting snow!!!!, if it werent either of them then youve cuaght some thing when youve had dash out!!! ;D
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 30 January 2004, 19:44 »
the only way you could get smoke coming in would be if your engine was smoking anyway and instead of the smoke leaving the engine bay it was entering the 'fresh' air intake which is under the plastic cover near the screen. If it is steam then your matrix could be about to die and is leaking.
Offline mk1
« Reply #3 on: 30 January 2004, 20:25 »
Heater matrix ??? ???.
Steve.
Offline jasonpi
« Reply #4 on: 30 January 2004, 20:32 »
heater matrix not connected at the mo?! could this be the problem?
Offline mk1
« Reply #5 on: 30 January 2004, 20:35 »
No, is the fan motor working ok?. Have seen some go tight and over heat causing smoke.
Steve.
Offline jasonpi
« Reply #6 on: 31 January 2004, 06:52 »
i think so comes on when car is switched off never heard it on when driving
Offline mk1
« Reply #7 on: 31 January 2004, 07:56 »
I mean the heater fan, not the radiator fan. If the heater fan motor bushes start to sieze, this causes the motor to overheat and could be where your smoke is coming from.
Offline jasonpi
« Reply #8 on: 31 January 2004, 09:44 »
right update took the car out for a spin this morning and it started again.....oil temp low water temp halfway...open bonnet smoke coming from the radiator/fan area.....i thought i fixed this as i put a new sensor on it ages ago and did work.....
kniterider
« Reply #9 on: 31 January 2004, 09:47 »
is it using any water?? is it steam or smoke??
maybe youve had stone in rad???
