Author Topic: Audible warning for headlights.  (Read 1858 times)
Offline lordbigsack
« on: 22 March 2007, 17:46 »
HI, I have a mk2 90 8v gti which the missus drives (caveats out the way) and need an audible warning for when the lights have been left on and the ignition is off.  Like you get on newer cars :wink:  Am fed up of flat batteries and jump starts.  Has anybody else done this, ideally it would take 5mins to do and cost FA !
S
Things I need (Mar 08): 1990 Drivers door in calypso green for 3door - someone must have one!
Things I have found: (Mar 08)Power steering pump bracket, sun visor clip
Offline rowlers
  • I'm back - MK7 GTI
Re: Audible warning for headlights.
« Reply #1 on: 22 March 2007, 20:17 »
check the maintenance section sure there is a how to in there!!
Well I followed instructions from somewhere! :grin: :grin: :grin:
Offline Agreeable Slick
  • Unit
« Reply #2 on: 22 March 2007, 20:40 »
I find shouting usually does the trick.  :smiley:
Offline ...joe
« Reply #3 on: 22 March 2007, 21:05 »
i had a look in the maintenance section but couldn't find it! sure its on here somewhere, its as simple as wiring a buzzer to a few different feeds i think.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline takethefifth
« Reply #4 on: 22 March 2007, 21:18 »
Offline lordbigsack
« Reply #5 on: 22 March 2007, 21:29 »
Thanks,  couldnt find it myself.
Will be in maplins tomorrow buying a buzzer :grin:
S
Offline JMallows
« Reply #6 on: 25 March 2007, 11:05 »
I must update that actually, as i have a better method, that means it only works with the ignition off, as its annoying the buzzer coming on if you let someone in or out etc...
A clever person solves a problem. A wise person avoids it.
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #7 on: 25 March 2007, 11:50 »
that sounds good cuz i have done one and although its saved my battery a number of times it does get annoying occasionally.
where do i connect up to for it to operate only with the ignition off then dude??
Offline rowlers
« Reply #8 on: 25 March 2007, 12:41 »
Super - come on lets have the update :wink: :wink: :wink:
Offline JMallows
« Reply #9 on: 25 March 2007, 15:19 »
I'll try and update the link in maintenance soon ok, will let you know when its done :)
