Author Topic: LED lights (I just bought a Mk5 GT TDI 2.0 3dr black w/Grand Prix 17in wheels)  (Read 4326 times)
Offline Teutonic_Tamer
I am possitive the indicators were LEDs, you can tell LEDs due to their on/off flashing is immediate unlike conventional bulbs that fade in and out
No Golf Mk5 has rear LEDs.  The Golf Plus, and the Jetta and Passat do have LEDs.
The reason the Golf rear lights are so impressive, is that they use a 6watt mini-halogen, and "overpower" it, via ECU and CAN-BUS control.  They do look quite different to conventional tungsten bulbs.
« Last Edit: 23 March 2007, 14:12 by Teutonic_Tamer »
I feel like a homo
Offline gonnahavemesomefun
What does everyone reckon?
Volkswagen Golf MK5 Angel Eye Projector Headlights
http://www.essexracing.com/product_info.php?products_id=677
Utter shyte !!!
Quote "These lights also include a projector lens as the primary light source, which allows more light to come out of the headlight" - opinion: b0ll0cks, the bulb is the light source, not the fcuking lens!
Quote "It also has a wider light beam pattern than most reflector-housing headlights" - opinion: b0ll0cks, if the beam pattern is wider (beyond the prescribed pattern), then it is not Type Approved!
Quote "this new LED Halo Angle Eye is one of the coolest designs ever" - opinion: maybe if you are a Chav!
Furthermore, it uses H1 halogen bulbs, which are hugely poorer than H7s.
I feel like a homo
