The garage
Washer Jet problem
Topic: Washer Jet problem (Read 1806 times)
danhock
Washer Jet problem
29 January 2004, 10:47 »
Washer jets stopped working this morning.. Its not blocked or frozen, i checked...
When i trigger it the wipers dont go either.. Is there a fuse or relay for this?
The wipers work fine normally.
Thanks
Dan
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
AdamB
The Perfect Storm
Re:Washer Jet problem
29 January 2004, 12:32 »
I get this problem in the cold on mine, including no wipers!- chances are its a frozen pipe, pump, or any other part. Run the car, get the engine warm, then let it try and melt whatever causes the blockage. Always works for me
I don't own this anymore - I just can't be arsed to change the picture
danhock
29 January 2004, 14:58 »
The car was run this morning and they worked fine but died half way to work.
I think the fuse might have blown but i dont know which one it is! (no cover of fuse box)
dubboy 79
29 January 2004, 20:25 »
its fuse number 11 (15A) and there is a wiper relay too.
check these first if you can't hear the washer motor working.
does the washer work when the wipers are in position 1 or 2? if yes, then check the switch contacts at the steering wheel too.
finally put a test lamp in the green/red wire connector that goes into the pump and earth it to a reliable point. if ok, it is either the pump or check for a bad earth at the earthing rose near the o/s headlamp.
good luck
'74 Golf "Special"
'76 Golf
'76 Golf L
'76 Golf LS
'76 Golf GTi
'79 Golf GTi
'80 Golf GTi
The garage
Washer Jet problem
