Author Topic: Optimum ignition timing?  (Read 1004 times)
Offline DG370
« on: 14 March 2007, 22:06 »
hi guys n gals, for performance on a stock '88 16v gti what ignition timing is best?
Re: Optimum ignition timing?
« Reply #1 on: 15 March 2007, 10:11 »
set it to the stock 6 degrees BTDC, then advance it by ear till it starts to pink, then back it off a tad.  Take it for a test drive and keep an ear open for pinking, if you get any, back the timing off a bit more.
If you want to get the very best out of it, make sure you run it on optimax for a couple of weeks, make sure you get rid of any cheaper stuff.  The higher the octane the more advance you'll get out of it!
