Author Topic: Caliper bolts seized  (Read 1303 times)
Offline mattp1983
  • Keep it VAG :)
« on: 14 March 2007, 18:58 »
Hey peeps, just spent last evening taking wishbones and front brake set up off my 8v GTI, Came to take brake discs off on drivers side, caliper bolts have rounded slightly and are seized, must be previous owner, any body got any ideas how to remove them, they are the allen type.
Also, bought powerflex rear wishbone bushes to fit, found the drivers side front one is knacked too, is it worth uprating those as well or is factory ok?
Cheers.
Matt.
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
Offline vaughn
  • now team wagon, and team grumpy trainee
Re: Caliper bolts seized
« Reply #1 on: 14 March 2007, 19:52 »
i would upgrade them all with powerflex bushes, and wd40 left to soak overnight then mole grips
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline mattp1983
  • Keep it VAG :)
« Reply #2 on: 14 March 2007, 20:32 »
Cool cheers mate, can u remove the rubber gaitors from the caliper which cover the bolts or are they bonded?
Offline *tell*
« Reply #3 on: 14 March 2007, 21:57 »
my caliper bolts were sezied and rounded off as well
ended up hammering a spined drive socket into it (cant think of the size)
then managed to get them out. also did use alot off wd40 :wink:
then got new bolts from a place hatfield called MURRYS the guy
was very help full.
Offline jv
  • Administrator
« Reply #4 on: 14 March 2007, 22:06 »
that's a great shop that :afro:
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline mattp1983
  • Keep it VAG :)
« Reply #5 on: 14 March 2007, 23:10 »
Thanks guys, got the new bolts in anticipation of this (car has done 2k a year since 97, discs were last changed at VAG in 1994, lol. Have most of the receipts for the car from new) But the passenger side they are siezed in the silver sleeve, can you buy these or do I have to get them in a vice and unscrew the gits?
Offline mattp1983
  • Keep it VAG :)
« Reply #6 on: 17 March 2007, 17:12 »
Hey I thought I'd give an update on this in case anyone has similar troubles, tried everything to get them off, in the end a 12mm impact socket was hammered on and it loosened straight off, fits really well on the bolt head, had to trim the rubber gaitor but will just grease the new bolt lots when it goes in, can recommend this to anyone with a rounded off allen bolt.
Thanks for all the suggestions guys.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #7 on: 17 March 2007, 18:42 »
hmm wishbone bushes theres a though, im getting my BBj's changed this coming week (have done new forn bearigns and hubs new apssenger tie rod and end new end drivrs side now 2 new ball joints are gonig in the mixture to completely sort out the front end.. only thing elft is 2 rear bearings, made my car a LOT quieter jsut doing the fronts..)
basically, whats the deal with wishbone bushes, while its all off and about are they worth getting done or will they be easy enough to do another time?  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline vaughn
« Reply #8 on: 17 March 2007, 18:46 »
i would do them while they are off and replace with powerflex items
