Golf mk2
brakes
Topic: brakes (Read 2721 times)
jasonpi
brakes
29 January 2004, 09:13 »
ive done fords before but how hard is it to do brake disks and pads front and rear?
jasonpi
Re:brakes
29 January 2004, 14:05 »
anyone
Dizzie
Forum addict
Make friends with your fast
Re:brakes
29 January 2004, 14:07 »
fairly easy.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
jasonpi
Re:brakes
29 January 2004, 14:12 »
cheers for that.....
golfvr6
Guest
Re:brakes
29 January 2004, 15:11 »
fronts easy
rears a bit of a pain, need to do the bearings, and sometimes the handbrake cable can stick on.
jasonpi
Re:brakes
30 January 2004, 13:42 »
cheers for that
do you need a special alan key to release the calipers??
Last Edit: 30 January 2004, 13:44 by jasonpi
golfvr6
Guest
Re:brakes
Reply #6 on:
30 January 2004, 13:45 »
On the fronts you will need an allen key, or a allen key socket would be better. Beware of the bolts rounding off, so get a new set and guides from vw.
jasonpi
Re:brakes
Reply #7 on:
30 January 2004, 14:11 »
cheers
modulater
Re:brakes
Reply #8 on:
31 January 2004, 17:59 »
When you do the backs you need a piston push in tool that you can get from halfords.
Veedubgt18v
Guest
Re:brakes
Reply #9 on:
31 January 2004, 19:19 »
or you can bodge it with a 'g' clamp
Last Edit: 31 January 2004, 19:19 by Veedubgti8v
Golf mk2
brakes
