Author Topic: best oil / oil light flashing  (Read 1058 times)
Offline gtilover
  • loving the restoration/modifying dub sceane
« on: 12 March 2007, 20:42 »
what is the best oil for my mk1 cabby 89 gti     also the oil light flashies when ignition is on but when i start her up the light goes off what could the problem be any ideas as to a fix this problem also how much oil will i need to do a oil change as im doing it this weekend
dub 4 life
Re: best oil / oil light flashing
« Reply #1 on: 13 March 2007, 10:53 »
the light should flash with the ignition on, its normal.  The light warns you that you have low oil pressure, which will be the case when the engine is off ;)
Quantum Synta silver from your dealer, GSF or AVS will be fine, some find it a bit thin but worked great in my 160k GTI engine!
