Author Topic: fuel pump priming on gti, when ignition goes on  (Read 1599 times)
Offline theruler
« on: 12 March 2007, 17:42 »
you know when you switch on the ignition, and the pump whirrs for a second, then stops?
well, when the pump doesn't come on like that, and has to be on a seperate switch, why is it?
what stops it working off the ignition?
i have had this in the past on my mk1 gtis, but it was a good while back before internet
Offline VapourTrails
Re: fuel pump priming on gti, when ignition goes on
« Reply #1 on: 12 March 2007, 18:11 »
i can only think of dodgy wiring but i have never heard of you having to have it that way, the relay in the fuse board should sort all that out.
« Reply #2 on: 13 March 2007, 10:55 »
there should be a relay that handles this, it sounds like someone has bodged the wiring to it!  If someone has wired it to a switch this is very dangerous, as in a crash the fuel pump could carry on running and spray petrol everywhere!
