Author Topic: What grade of oil is best?  (Read 4652 times)
Offline R32_T
« on: 28 January 2004, 18:47 »
I've been using Castrol GTX Magnatex 15w/40 since I bought my car. Its done 59K now. Some one told me that I should use a lower grade. Could any one help me out on what grade I should use. Any advice would be much appreciated.  :)
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
golfvr6
Re:What grade of oil is best?
« Reply #1 on: 28 January 2004, 19:28 »
My personal preference is quantum synta gold.
Offline R32_T
« Reply #2 on: 28 January 2004, 19:30 »
I'll have to look into that.
Cheers mate!
Offline nrgizerbunny
« Reply #3 on: 31 January 2004, 18:37 »
okay this might be techie but i'll say it anyway and most of you probably already know this.
the oil grades commonly used in this country are based on the SAE (society of automotive engineers) index. and are typically xxWxx (eg. 10w40, 0w40)
the first number is the viscosity of the oil when it is cold (the "w"means winter). and the lower this number is the better. most engine damage is done when the engine is cold because oil is vicous and is more like treacle than oil.
the second number is the viscosity of the oil when it is hot and in most respects the oil is pretty much always gonna be 30, 40 or 50. (most petrol cars require 40, and diesel pd's need 30)
it is the winter value i would take note of, the lower this number is the more runny the oil is and the faster the oil will lubricate your bearings and other things. the oil will also heat up faster so the bearings will cool down and you get sufficient hydrostatic pressure on the white metal bearings.
also 15w40 is usually mineral oil (refined crude oil) although it can be sometimes semi synthetic (i.e partly made by people in white coats). 10w40 is pretty much always semi synthetic.  5w and lower  is pretty much always fully synthetic.
My personal preference is mobil 1 0w40 (when i had a petrol car) it is expensive but on cold days there is a definite improvement on the speed at which the engine heats up and the noise is reduced to. also fuel consumption on short journeys is improved. just my opinion but i thought i would share it anyway
hope this helps
sanj
Offline LeeFS
« Reply #4 on: 06 February 2004, 15:05 »
Is it ok to use synthetic oil for 1.8 turbo? I currently need to top up mine and Ive got some 5w40 (halfords)
kniterider
« Reply #5 on: 06 February 2004, 16:50 »
i use fully synthetic mobile 1 in my golf, 10w40 i reckon but im gonna try fully synthetic morris oil later this month ;D
Offline R32_T
« Reply #6 on: 07 February 2004, 19:25 »
I think i'll carry on using 15W40 as i said before my cars done 59K. I think if I use thinner oil then the engine might sound louder.
« Reply #7 on: 09 February 2004, 09:54 »
the thinner oil is actually better, the ultimate viscosity ie 40 is the same in both cases, the cold viscosity is better if its thinner. 15 is like treacle but 0 is almost like water, it'll rush round and lubricate your bearings faster.
kniterider,
isn't mobil 1 0w40? 10w40 i thought was semisynthetic.
sanj
Offline m4nesh
« Reply #8 on: 09 February 2004, 19:13 »
hey all
My moms vw golf with a 1.4 engine(yeah!! Its slow to f**K!!) has just done 6k and it needs a bit of a top up of oil.
Can anyone tell me what grade of oil it takes.
ie Is it multi grade oil or semi syn
and what rating eg.. 10w 40, 15w 40 etc....
all the best
Manesh
