Author Topic: ABS Faults  (Read 1318 times)
Offline Slasher
ABS Faults
« on: 09 March 2007, 19:02 »
I sure most people already know about this but in case you don't I will share a bit of knowledge I've gained about MK3 ABS Faults:
Recently I've been getting the ABS light coming on intermitently on the dash so I invested in a VAG-COM cable to investigate... it reported two faults, a front left and rear right sensor.  Rather than jumping in a buying new sensors I decided to give them all a good clean with brake cleaner and a cloth which has cured the front left but not the rear right... I went to see the main dealer thinking I would need to get rear sensor fitted but luckily the mechanic was a real expert on the MK3 and suggested it may well be the controller (fitted to the bottom of the ABS pump) and not the sensor at all - he suggested swapping the left and right wires over for the rear and see what fault it comes back with, obviously it should now read a fault with the rear left sensor if the sensor was faulty, if it still reads rear right faulty you know you have a faulty controller (v expensive I think)
Anyway, the bad news for me is it looks like the controller is at fault on mine and not the controller!  Great - more expense :angry: Hope some of you find this helpful if you have similar problems!
P.S. I gather that you have to replace the controller and pump together on the 16v
J
MK3 16V Blue, Miltek, BBS.
Offline EvilScotsman
Re: ABS Faults
« Reply #1 on: 10 March 2007, 13:18 »
What about doing the ABS pump purge routine as you have vag-com? I havent tried it but have details on how to do it, dont know if it would help but might be worth a shot since its free:
(quoted verbatim from ross-tech)================================================
This procedure details how to bleed the ABS pump when replacing brake fluid. This procedure is NOT necessary unless your ABS pump has gone completely dry. For normal brake work including fluid replacement, hose replacement, pad replacement, etc. this procedure is NOT necessary. Also, this procedure does not take the place of good ol' fashioned brake bleeding with one person operating the pedal while the other person opens the bleeder valves one by one and collects the discharged fluid.
There are certain test conditions that must be met before doing this procedure:
Vehicle must on a lift or safe jack stands with no wheels touching the ground
Ignition should be in the "On" position
Procedure for Bleeding the ABS Brake Pump on VW Golf, GTI, Jetta, and Audi TT:
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 001
[Go!]
This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.
Click the [Done, Go Back] button and you're all set.
I was thinking maybe you have a line lock or something wrong from the pump to one wheel but i suppose now i think about it the fault did stay with the input pin for that sensor on the controller so it does look like its faulty. Just pull one off a scrapper as long as the part number is the same i.e. teeves 04 - 1H0 907 379 D
"Handheld OBDII Scanner"
