Author Topic: Strange Whine!  (Read 1175 times)
Offline kkh120
Strange Whine!
« on: 07 March 2007, 11:03 »
Sounds like a bearing or something has gone on the fuel pump of my 8v.
Can this be repaired or is it best to get a replacementb unit.
For a replacement, is a new one very expensive or just go for a scrappy part?
Cheers.
Mk2 8v and 16v.
Always looking for bits!
Offline takethefifth
Re: Strange Whine!
« Reply #1 on: 07 March 2007, 12:33 »
Is it the pump engine side or the lift pump in the tank?   I know for the lift pump i found it easier just to get a replacement from GSF. Worth doing that one soon though as the extra strain on the main pump will cause it to fail shortly after.
Offline Organisys
  • Old and Slow...
Re: Strange Whine!
« Reply #2 on: 07 March 2007, 12:58 »
Could be a female in the passenger seat ?
 :grin:
 :evil:
Offline kkh120
Re: Strange Whine!
« Reply #3 on: 07 March 2007, 13:38 »
 :grin:
 :evil:
Nice :grin:
Mk2 8v and 16v.
Offline Simon8v91
Re: Strange Whine!
« Reply #4 on: 07 March 2007, 16:36 »
LOL  :laugh:
If the whine disappears when the tank is full of fuel only to come back later when you have used some then its the lift pump inside the fuel tank that has died.  The whine is the main pump overloading or air bleeding through becasue the lift pump is not supplying fuel to it.
The lift pump is easy to change, through the blanking plate in the bottom of the boot.  I would recommend a VAG one.  I got one from GSF but it is quite noisy and does not fit the OE strainer.
VAG: 191 906 092 AD  £24.03 I think but get the dealer to confirm part # first.
Edit: replaced fuel pump with fuel tank doh!
« Last Edit: 08 March 2007, 16:25 by Simon8v91 »
Offline kkh120
Re: Strange Whine!
« Reply #5 on: 08 March 2007, 15:57 »
Spot on, thanks for the info :smiley:
Mk2 8v and 16v.
