Author Topic: Sare Heed!!!  (Read 1208 times)
Offline c8lnj
Sare Heed!!!
« on: 06 March 2007, 18:10 »
Finally got round to whipping the suspect gasket off my mk2 8v this afternoon - as suspected its cooked between 3 & 4.
Fair chunk of its gone is there anything else to look at before whipping a new one on & tightning it up??? Bores look fine.............Ive got a spare block & heed sat in the shed, not sure what to do!!! Head was last done 10 months before it failed again, under 10k!! Work was carried out by quite a large well known garage (not saying its been done wrong) but what could cause this???
Offline Thom89
  • Looking for an "Icebreaker"
Re: Sare Heed!!!
« Reply #1 on: 07 March 2007, 01:53 »
Get your head skimmed before refitting!
Tom
Offline ...joe
Re: Sare Heed!!!
« Reply #2 on: 07 March 2007, 08:47 »
i don't think they fully tightened the headbolts, or didn't use new ones. also get a g60 headgasket, they're about £35-£40 but are proper heavy duty.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Sare Heed!!!
« Reply #3 on: 07 March 2007, 17:26 »
Definately get the head skimmed and check that the deck is not warped too. Also, make sure that the head locating pins on the deck, (top of the block) engage properly into the head. If they are corroded or the pin holes in the head are corroded, the head may not torque down properly.
Offline c8lnj
Re: Sare Heed!!!
« Reply #4 on: 08 March 2007, 03:06 »
Thanks for the replies, the heads got a sizable chunk out of it aswell.....ive not chacked the tolarences but think its not usable. So im working with the spare head ive decided. Just need to get the valves refaced & cut into the head.
Whats best to clean up the head & block surfaces...ive got some degreaser but its not really doing much good!!
Offline DarnPB
Re: Sare Heed!!!
« Reply #5 on: 08 March 2007, 15:56 »
I used diesel to clean my head, followed by a Karcher pressure washer, then dried it with compessed air. Came up like a new pin. :smiley:
