Author Topic: Brake Upgrade?  (Read 3244 times)
Offline Uj
Brake Upgrade?
« on: 05 March 2007, 23:27 »
Hi,
Just had my 1.8T serviced, my front pads and discs need replacing. Quoted £200 for 3rd party new front discs, pads and fitting. Seen a 312mm TT upgrade kit floating around on Egay for about £225. Did a bit of research and can't seem to find out whether they would fit the original Montreal 1 alloys I have. Also if i did get these how much I am looking at to get these fitted? Car is a completely bog standard 1998 AUG at the moment.
Any tips/info appreciated.
Offline Rhyso
Re: Brake Upgrade?
« Reply #1 on: 06 March 2007, 10:02 »
what size are your Montreals? if they are 16's then it will perfectly.  I've got the montreal 2's and the brake upgrade.
Is the ebay member 'golfturbo'?  If so then i recommend him as I've bought the kit from him.
I paid my local mechanic £20 to fit them for me.
Offline Uj
Re: Brake Upgrade?
« Reply #2 on: 06 March 2007, 12:43 »
Rhyso - Got the standard 16" montreal I's and yes ebay memeber is Golfturbo_com. Are there any other 312mm upgrades I should look at or that can be recommended?
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Brake Upgrade?
« Reply #3 on: 06 March 2007, 13:41 »
That kit's the cheapest you'll find!  Just sell the calipers on when you get it!
I've recently bought (yet to fit) a 2nd hand set of the 312mm's.  I've been told by Golf Turbo & other dealers that they fit under the 16" Monty 2's (not sure about the Monty 1's, though) - I probably won't be finding out for sure for a while now, as I've got the 18" Anni's back on my car, now.
Ps  What did you mean by 'other' 312mm upgrades?
Ivor
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Uj
Re: Brake Upgrade?
« Reply #4 on: 06 March 2007, 14:59 »
Thanks Ivor. By other upgrades I meant are there any aftermarket non VAG Pads, discs and calis only (312mm), or am I looking at the expensive kits by Brembo, Tarox or Neuspeed etc?
Re: Brake Upgrade?
« Reply #5 on: 07 March 2007, 14:15 »
Well, the beauty of the 312 setup, is that you can bolt the carriers, discs & pads straight on using your existing calipers, thus saving the need to mess about bleeding the brakes/changing the brake fluid etc.
I've done a few track days, & have always been a firm believer in uprating my pads but running cheapo discs (I find that the drilled and/or grooved discs only wear the pads out quicker!).  I'd go for likes of Ferodo DS2500's/Mintex/Pagid pads.
The bigger brake kits (including the R32 setup) will cost you a fortune & also the extra forementioned hassle.
« Last Edit: 07 March 2007, 14:17 by Ivor Mk4 Turbo »
Offline Uj
Re: Brake Upgrade?
« Reply #6 on: 07 March 2007, 15:27 »
Thanks Ivor - so just to make sure everything on this TT kit will fit be a straight swap apart from the calipers?
Re: Brake Upgrade?
« Reply #7 on: 07 March 2007, 17:05 »
Yep - Either keep the calipers as spares or sell them on ebay/here/ukmkiv's.net etc.
He won't split the set, as many have asked before, LOL!!
Offline Uj
Re: Brake Upgrade?
« Reply #8 on: 13 March 2007, 13:10 »
Looks like you got a good deal to get yours fitted, my local mechanic has quoted me £65 + VAT.
Re: Brake Upgrade?
« Reply #9 on: 13 March 2007, 13:42 »
Yes - I got a very good price.....  FREE, as I'll be fitting it myself!!!   :grin:
£65 + VAT seems a lot to me - I'm sure I've read somewhere that some body paid only £20.
If I was you, I'd go down to a local place on a Sat, & see if the Saturday boys will sort you out.
