Author Topic: Oil sensor  (Read 1038 times)
Offline Philpy
Oil sensor
« on: 05 March 2007, 20:51 »
Anyone know the part number for the 2 oil sensors on a 16v? Think mine are playing up. Been looking on eurocarparts but am not sure what I need!
Thanks
Offline takethefifth
Re: Oil sensor
« Reply #1 on: 07 March 2007, 23:15 »
If you look here (in the stickys at the top of the page)  http://www.golfgtiforum.co.uk/index.php?topic=33909.0
I think Slick lists them in his 2nd post.
Offline Philpy
Re: Oil sensor
« Reply #2 on: 08 March 2007, 14:26 »
I had seen this, but from searching this forum other people have said there are only 2 sensors, but Slick lists 3......... So now Im confused!
Re: Oil sensor
« Reply #3 on: 08 March 2007, 18:51 »
Good point!  Not having a 16v myself i am not sure...  I would give GSF or a VW dealership a ring and get the part numbers off them if no one with a 16v replies.
Offline Philpy
Re: Oil sensor
« Reply #4 on: 08 March 2007, 21:49 »
Thanks for your reply anyway! Anyone know??
Re: Oil sensor
« Reply #5 on: 12 March 2007, 11:39 »
056 919 081 E - Oil Pressure Switch (1.8 BAR 1 pin White) - 8.21+VAT
028 919 081 D - Oil Pressure Switch (0.25 BAR 1 pin Blue) - 8.21+VAT
The blue one replaces the old black/brown sensor you have :)
Offline Philpy
Re: Oil sensor
« Reply #6 on: 13 March 2007, 11:38 »
Ah cheers, but that second one you listed is a different one again from slicks post in the part numbers post!  :laugh: So now thats 4?
Re: Oil sensor
« Reply #7 on: 13 March 2007, 11:44 »
yep, thats cos slick didn't post up the low pressure sensor as fitted to all MK2s ;)
Those are the 2 you need :)
Offline rowlers
  • I'm back - MK7 GTI
Re: Oil sensor
« Reply #8 on: 13 March 2007, 20:10 »
which "sensors" are you after??
the ones on top of the oil cooler or the three on the side of the head (under dizzy).
I think RJ has given you the part numbers for the oil pressure switches on top of the oil cooler.
