Author Topic: Mk2 front suspension top mount conversion. PR 2E1  (Read 1012 times)
Offline dubmaster77
  • actualy on the road!
« on: 04 March 2007, 17:04 »
Hi all!
I recently read in a popular vw publication that it is a good idea to replace the mk2s suspension top mounts with those of the mk3 gti using part number or kit number PR 2E1.
I orderd the parts using this number, Namely the top mounts ond top spring plates. as soon as i saw the top plates i knew they would be to small and this was confimed when i removed the strut it also be came clear that the top mount would not work as it has no internal bearing. the problem is that obviously they will not take these parts back as they were orderd VOR. Does any one know if i need any other parts to complete this conversion or ordering the mk2 g60 top mounts as advised in tim styles performance golf manual???? I am lowering my car using a -40mm weitec springs and uprated shocks.
Any advice gratefully accepted! :rolleyes:
K-Jet is my friend!
sacvwgolf
Re: Mk2 front suspension top mount conversion. PR 2E1
« Reply #1 on: 04 March 2007, 18:12 »
g60 top mounts are a straight swap and are more tougher and better
Offline dubmaster77
« Reply #2 on: 04 March 2007, 22:40 »
Are the g60 top mounts availible from gsf/ euro car parts??? Do you know the part numbers??? :grin:
K-Jet is my friend!
