Author Topic: Unknown engine sensor  (Read 876 times)
Offline heinz
« on: 04 March 2007, 13:23 »
 I have found a disconnected wire behind my fuse box? it  con checks to a sensor below the ISV that is bolted to the inlet manifold bracket same sort of size shape of a oil pressure sender   wire color is brown and black  engine is 2E
any ideas
 Thanks in advance Si
« Last Edit: 04 March 2007, 13:54 by heinz »
Offline EvilScotsman
Re: Unknown engine sensor
« Reply #1 on: 04 March 2007, 15:05 »
IAT?? Inlet air temp maybe - i have an ady engine so not sure mate
"Handheld OBDII Scanner"
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« Reply #2 on: 04 March 2007, 22:32 »
alarm bells rang when i read your post bud. what year is your car. sounds like its had an engine swap from agg or ady to a 2e which didnt have the air intake sensor. either that or vw have used the ady/ agg loom on the transition from the older 2e to the ady/agg. trasition took place in 1994 i think. :undecided:
