Author Topic: ME COLD!!!  (Read 2139 times)
Offline Sweety
ME COLD!!!
« on: 27 January 2004, 11:57 »
 >:( my car heaters are crap. There is hardly any power in the ehaters when you turn them on full whack.
Hardly any heat comes from them, so as you can imagine in these - degree temperatures- im pretty cold!  :-[
Any thoughts?
Offline D Owen
Re:ME COLD!!!
« Reply #1 on: 27 January 2004, 12:05 »
Wear a wooly hat and a jumper  ;)
Offline Gambit
Re:ME COLD!!!
« Reply #2 on: 27 January 2004, 12:12 »
does your fan work on all 3 setting?, does it blow any heat at all
might be worth your while giving the blower a bit of a service with wd-40, and some grease - loosen it up a bit
then flush the coolant and refill properly to prevent any airlocks
also, your bypass valves may be knackered
Offline Mirage-
Re:ME COLD!!!
« Reply #3 on: 27 January 2004, 16:09 »
Sorry to hi-jack your post but...
My heaters take their time to get to temperature but once they are and I'm driving at a reasonable speed (30mph+) the heat becomes really intense.  If I'm then made to stop in traffic the heat disappears and cold or colder air is blown out.
Any ideas?
Ian
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
Re:ME COLD!!!
« Reply #4 on: 27 January 2004, 16:59 »
Sweety- my fan was crap until i had to change the heater matrix, the old one was manked and blocked up, now flows sweet! but i think the by-pass valve is f**ked cos the best i can manage is, luke warm!
Mirrage- What temp dose your car run st, dose the fan kick in when ever you stop? When my fan kicks in If i've been sittin in traffic ect, i get a cold rush off water thourgh the system and my blowers try to freeze my nuts off......
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline Malky
Re:ME COLD!!!
« Reply #5 on: 27 January 2004, 17:00 »
Mines are the opposite.  Whilst sitting still you get a nice heat from then but as soon as you start driving, the heat goes from nice to lukewarm.
Offline Rob
Re:ME COLD!!!
« Reply #6 on: 27 January 2004, 21:30 »
my heater used to be brilliant until sat in traffic and oil temp would rise to 100 then it would blow freezing cold air.
changed heater matrix and the rubber hoses from bulkhead and all seems fine. the hose from bulk head which goes to the metal pipe on engine had a slight kink. now everthing seems a ok.
and im glad as its fecking freezing out there
Offline rustynuts
  • God is a DJ
Re:ME COLD!!!
« Reply #7 on: 27 January 2004, 23:34 »
If it goes cold when at a standstill could be the water pump, the impellor can rust away making waterflow a bit crap over time. so when at low engine revs its not moving the water well.
