Author Topic: whining in gear box  (Read 1358 times)
Offline opel
whining in gear box
« on: 26 February 2007, 20:41 »
i got a whining noise from my gear box wot best way to sort it with out recon box
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: whining in gear box
« Reply #1 on: 26 February 2007, 20:55 »
have you checked the gearbox oil??  is it leaking??
If it's whining already, it's probably on it's way out.  You could try changing the oil for a decent synthetic.. might buy you some time before the inevitable
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline Len
« Reply #2 on: 27 February 2007, 09:15 »
Probably too late as its most likely the main shaft bearings. But check the oil first.
www.sas.org.uk
www.the-ace.org.uk
Offline opel
« Reply #3 on: 27 February 2007, 20:00 »
checked the oil and replaced it but not a high spec oil but it still wines might have to try a better oil
Offline Len
« Reply #4 on: 27 February 2007, 20:12 »
Use the thickest gearbox oil you can find.
www.sas.org.uk
www.the-ace.org.uk
Offline wernley8vgti
« Reply #5 on: 28 February 2007, 18:55 »
hi pal same prob try mollyslip gearbox treatment,in youre box,you can get it from halfords for 6quid,it will improve youre box no end if no good still then recon or get a tdi box.
