Author Topic: wheels problems.  (Read 994 times)
Offline nicol_vw
wheels problems.
« on: 25 February 2007, 18:37 »
hey guys please someone help, my mate has some borbet alloys, which i want but my mk3 has 5 stud alloys on at the mo, and his wheels are only 4 stud will they fit?
my car is a Jreg GTI 8V
the wheels are 16" borbets (A's) i think. stud diameter is 100, and rim width is 7.5j.
someone please help!!!!
cheers guys
Offline ROB3611
Re: wheels problems.
« Reply #1 on: 25 February 2007, 19:55 »
Ummm, nope, they wont. The clue was that they are 4 stud and your car has 5. :wink:
Offline EvilScotsman
« Reply #2 on: 27 February 2007, 23:22 »
Mate, the 100 refers to the pitch circle diameter (pcd) which is the circle that runs through all the bolt centres on the wheel.
If you draw a 100mm diameter circle wi a compass, then put 5 equally spaced marks on the circle, they will be 72 degrees apart.
Put 4 equally spaced marks on it, and they will be 90 degrees apart. Surely its obvious they wouldnt fit!
You get 4 to 5 bolt adapter plates but not the other way round. 5 bolt wheels are safer than 4's thats why manufacturers started doing all cars this way. An extra hole and wheel bolt on 5 million cars is a lot of extra cost just on one make of car. VW wouldnt do that for no reason.
Find a set of 5 bolt wheels you like and get them. Forget the 4's they are no use to you, Search for "alloy question or read that post - I put up a list of cars wi their pcd's etc, you can find cool wheels on other cars (scoobies for example) that will fit straight on the mk3. The offset (ET) has to be nearly identical (up to 5mm over or under would be ok but beyond that would wear wheel bearings out prematurely and affect the steering geometry)
"Handheld OBDII Scanner"
Offline patch900
« Reply #3 on: 28 February 2007, 09:26 »
There are some posts on here about wheel adapters. They arent that expensive and it quite common to go from 4 stud to 5.
The only problem you might have is I think the adapters will push out your alloys slightly (i.e add width), so with 7.5" alloys on your at the max alloy width for a golf.  Without arch work your alloys might be pushed out of the arch and could scrub on the wheel arches.
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
