Author Topic: brakes different?? better now but...  (Read 1083 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 24 February 2007, 12:10 »
replaced rear calipers last week, mechanic bled the system..
Now the brakes are erm.. different :undecided:
the pedal has more travel now, I have to put my foot further down than I used to.
Also the pedal "pumps" up firmly with engine off, the pedal then goes softer when engine is running,  and will pump up again at idle then go softer when revs rise? What gives here? :undecided: :undecided: :undecided: :undecided:
any clues???
PS it wasn't presure bled because the garage didn't have a pressure bleeder, the pedal wasn't pushed all the way to the floor when bleeding as the kn@ckers the MCylinder I believe.
does the bias valve at the rear need to be opened to bleed?
« Last Edit: 25 February 2007, 15:46 by rowlers »
Offline rowlers
Re: brakes different?? better now but...
« Reply #1 on: 25 February 2007, 16:07 »
right re-bled all the brakes, now we are much better!!
But tried to clamp the bias valve thingy and it wouldn't move - mechanics words were "hmmm that hasn't moved for a while"!
how easy is it to replace, it will have to stay as it is for now, money pot is empty!
Last problem was the bleed nipple was missing from the front drivers side, can they be replaced or is it a new caliper?
Offline richard s
« Reply #2 on: 25 February 2007, 21:14 »
when i bled mine the bias valve lever had no resistance but bled ok and the brakes seem fine and bleed valve can be got from vw but there is two different sizes
« Reply #3 on: 26 February 2007, 11:32 »
the nipple must have shered off, for all the effort & cost involved with getting it out, you might as well get a 2nd hand caliper. The compensators can be had for about £40 off ebay, or less if you're patient and wait for a bargain ;)
Make sure you invest in a brake pipe spanner when you come to replace it, otherwise you'll round off the brake line nuts.
Offline rowlers
« Reply #4 on: 26 February 2007, 17:43 »
Is the bias valve really important - or can I just wait for a bargain as you suggest?
sacvwgolf
« Reply #5 on: 04 March 2007, 22:06 »
Offline rowlers
« Reply #6 on: 05 March 2007, 22:28 »
superb!
