Author Topic: De locking  (Read 1654 times)
Offline Rideandy
De locking
« on: 23 February 2007, 19:30 »
I have just picked up a pair of rear door handles from ebay, so I can fit them to the front to delock. has anyone done this and is it easy?
Offline carl
Re: De locking
« Reply #1 on: 23 February 2007, 19:48 »
very easy and straight swap ,can be done without takeing door trim off inside but may be easyer if you havent done it before ,just undo the screw what holds the handle which is on the inside of the door just above door latch , pull handle out slowly and look inside to see where door handle fits around metal bar and replace the same way it come out ,sounds hard but very easy to do.
Offline Rideandy
Re: De locking
« Reply #2 on: 23 February 2007, 20:14 »
Nice one.
Thanks.
Offline EvilScotsman
Re: De locking
« Reply #3 on: 23 February 2007, 22:27 »
how will you unlock it if your remote fails?
"Handheld OBDII Scanner"
Offline neil_1821
Re: De locking
« Reply #4 on: 23 February 2007, 22:38 »
Isn't there usually something that comes with them so if it fails you press the switch and the doors open?
Offline Rideandy
Re: De locking
« Reply #5 on: 24 February 2007, 07:08 »
Brick!
Re: De locking
« Reply #6 on: 25 February 2007, 08:49 »
you only get a switch wi a kit, not when you take old rear handles off a scrapper neil  :grin:
Offline monkeyalan
Re: De locking
« Reply #7 on: 25 February 2007, 16:06 »
via the boot.  :wink:
Offline Rideandy
Re: De locking
« Reply #8 on: 26 February 2007, 07:45 »
Good thinking Monkeyalan, I had never thought of that!
Offline monkeyalan
Re: De locking
« Reply #9 on: 26 February 2007, 12:06 »
that could have been a bit embarrasing.  :laugh:
