Author Topic: 2litre conversion help  (Read 750 times)
Offline t111bul
« on: 21 February 2007, 20:33 »
Hi, I've got a mk2 16v 1800 that i use as a track day car but it just needs more power. I want to do a 2litre conversion to give it a bit more go, so what i really need to know is what I'd need engine wise and also what i can use from my 1800.
Offline hockeylad72
Re: 2litre conversion help
« Reply #1 on: 21 February 2007, 21:26 »
I believe you need a block engine code 9A, you can use your own alternator and starter motor use timing belt and head gasket from the 2.0 engine you use. Not sure about distributor might be a 2.0 one you need, but I'm sure someone on here will clarify for you
regards
Davie
