hi all as some of you know ive had a problem with my isv and after trying three i still had no luck so i spent a little time this evening looking at the wiring and found that three of them had snapped clean in half i found them behind my manifold i followed it round and the cable that was snapped was joint to the throttle house where the little clip is and then it also linked with the clip that joins onto the pipe that goes into the air hose so if any one is stuck check your wiring ive done redone the joints and everything is sweet.
