Author Topic: wiring need igniton live wires?  (Read 748 times)
sacvwgolf
« on: 20 February 2007, 17:08 »
hi i am after a wire that is under the dash that only comes live when the ignition is switched on, not on perimant. i tried the cig lighter but thats perimant. i also tried a big red wire going to the ignition barrel i think but that's live as well.  any ideas?
thanks
Offline Ben Lessani
Re: wiring need igniton live wires?
« Reply #1 on: 20 February 2007, 17:50 »
back of the fusebox on right hand side, theres tonnes of ign spade connectors.
sacvwgolf
« Reply #2 on: 20 February 2007, 18:03 »
oh right cool i knew there was spare earths spade connectors but not live. thanks, vw have thought of everything!
« Reply #3 on: 21 February 2007, 16:06 »
This is only true on pre-90 MK2s (hazard switch on dash).  For 90 spec MK2s the D plug has ignition live feeds, but you'll need to splice in your own pins.  See my fusebox FAQ!
The other option is to splice into the heater blower wire :)
sacvwgolf
« Reply #4 on: 21 February 2007, 16:39 »
ok i couldn't find the ign spade connectors so i hacked into a switch and got the wire i was after. thanks
