Author Topic: HOW DO I GET REV COUNTER TO WORK ON MK2 GTI WITH 20V TURBO CONVERSION.  (Read 1496 times)
Offline VeeDubNaz
HELLO PEOPLE IVE JUST FINISHED PUTTING IN A GOLF MK4 20V TURBO ENGINE INTO MY MK2 GOLF I WANT TO USE ORIGINAL CLOCKS I KNOW THIS CAN BE DONE BUT HOW DO I GET THE REV COUNTER TO WORK ON THEM, WHATS THE WAY TO DO IT?
Offline Fraiser
From what i understood to make this work you need to solder in a 1 k resistor to the coil trigger pin on to two of the coilpacks, IIRC its pin number 3 on the coilpack. ( if you only do one you only get half speed reading ). The remaining two legs of the resistor are then twisted together and a wire then run to the rev counter and it should work.
if you need someone to do this and are close to luton i have someone who can do it.
Faiser
