Author Topic: door pops  (Read 757 times)
Offline M41K1T
door pops
« on: 19 February 2007, 22:16 »
Hi
I Just bought a mk2 golf with clifford g5 already fitted, my question is i want to use 2 of the outputs it has as door pops for the rear doors, does it need a relay between the alarm and the solenoid??
Thanks in advance
Offline monzablue16v
Re: door pops
« Reply #1 on: 19 February 2007, 23:40 »
Best to Relay it, not sure of the current draw you can have from the outputs and those solenoids use quite a bit of power to pop doors,  don't forget to fuse the feeds to the relay :)
Offline M41K1T
Re: door pops
« Reply #2 on: 20 February 2007, 13:13 »
Nice 1
I am using solenoids that i bout from volks apart but they dont seem strong enough, do i need to connect it to the handle wire or on the actual door latch?
