Golf mk1
Heater Switch problems
Topic: Heater Switch problems (Read 2123 times)
M41K1T
GTI forum regular
19 February 2007, 15:27 »
Hi
I have just turned my heater switch on and nothing is happining, it was working fine yesterday, any1 have any ideas?
Cheeers
Last Edit: 19 February 2007, 15:49 by M41K1T
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re: Heater Switch problems
20 February 2007, 14:30 »
Could be a blown fuse or it might have a loose connection on the switch, wiggle it about a bit and try it again.
......now officially dubless.
M41K1T
GTI forum regular
20 February 2007, 16:09 »
Hey Gibby
Tried that no luck
any ideas wot else it could be?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
20 February 2007, 16:39 »
does it work on speed 3? if so the resistor on the motor has shafted. When was the last time you used it, the motor bushes may have siezed, spray a ton of penatrating oil on em whilst wiggling the fan blade
M41K1T
GTI forum regular
21 February 2007, 16:55 »
cheers will give that a go now
caddyrage
GTI forum regular
22 February 2007, 16:04 »
Had the same prob on my caddy. The resistance wire burned out on the plastic heater motor cover
. Swapped the wire and fuse and it works again. Let me know if you need the parts..... wire, switch or motor as i have spares
03 ibiza PD 130 sport, smiles per miles!
83 mk1 golf gti, 16v 2L PL
92 mk1 caddy, now stripped for resto
WWW.FENDUBBERS.CO.UK
cambridgeshire vw owners club
Golf mk1
