Author Topic: Hazerd switch  (Read 2498 times)
Offline M41K1T
Hazerd switch
« on: 19 February 2007, 15:20 »
Hi all
Just replaced my hazerd switch on mk1 golf but am getting buzzing noise from relay and nothing is working, is my relay broke?
cheers
Re: Hazerd switch
« Reply #1 on: 20 February 2007, 10:18 »
was it a new switch?
Offline M41K1T
Re: Hazerd switch
« Reply #2 on: 20 February 2007, 12:48 »
Yep bought new switch from gsf
Re: Hazerd switch
« Reply #3 on: 20 February 2007, 16:38 »
I'd look at the indicator switch next, early MK2 stalks fit a MK1 with some mods to the surrounds so I've been told :)
Offline M41K1T
Re: Hazerd switch
« Reply #4 on: 21 February 2007, 12:07 »
When i indicate or use hazerd the green light on dash just stays on doesnt flash, and relay has now stopped buzzing, i am off to buy a relay, hope that works :undecided:
Re: Hazerd switch
« Reply #5 on: 21 February 2007, 12:18 »
ive had this with a dead hazard switch, check the pin numbers on the back are the same as your old one.  Also make sure non o the pins has fallen out the back of the plug, and make sure u aint got any blown fuses ;)
Offline M41K1T
Re: Hazerd switch
« Reply #6 on: 21 February 2007, 12:53 »
Cheers will do
Offline Alps
Re: Hazerd switch
« Reply #7 on: 27 February 2007, 15:16 »
could also be the fuse for the hazards.
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline [han]
  • Graphic Designer for Haribo
Re: Hazerd switch
« Reply #8 on: 14 March 2007, 08:29 »
at UD last weekend, we had a similar problem with jon's car, the wiring had gotten wet in the boot, causing a problemw ith connection, after removing and checking all bulbs and fuses, they worked! not sure how, maybe something had just come loose!
hope you get sorted... have you checked that everything is in place?
Offline M41K1T
Re: Hazerd switch
« Reply #9 on: 16 March 2007, 13:11 »
 :grin:
finaly got hazerds working, yeaah,
wot a nightmare, checked connections in boot replaced relay and fuse and all was fine, same as u Han dont know how but thank god it works, cheers for help guys  :wink:
