Author Topic: De-Cat pipe?  (Read 2439 times)
Offline aggie vr6
De-Cat pipe?
« on: 22 October 2006, 11:54 »
Contemplating buying a de-cat pipe for a MK3 VR6 can anyone tell me the advantages/disadvantages of one, does it increase performance, fuel consumption etc......
Thanks :wink:
In Cornwall, Need a Valet, Call for a discount
Offline Uruk Hai
Starting motor woes !
« Reply #1 on: 01 November 2006, 18:59 »
Not long after I bought my 8V the starter motor started turning but not engaging everytime and eventually it got to the point where it wouldn't engage at all. Fortunately my mate had a spare engine and box in his garage so I had the starting motor off that one but today thats started to do the same thing although it engaged and started on the second try after just spinning freely the first. Could it just be that this second hand motor is just failing in the same way as the first one (it is older than the one I took off  :undecided:) or could it be a problem with the starting ring gear or something worse  :undecided: :undecided:. Any help really appreciated as I need the car everyday for work  :rolleyes:
Offline ozza
Mk3 16v GTi Idle Problem - With Video!
« Reply #2 on: 15 November 2006, 20:15 »
This just started today.
The car just won't idle at any temp of engine.
It does 2 things.
1). Start engine and it starts every time but pulses the idle RPM to just above stalling, then raises it to around 1300 RPM and then drops it again to around 700 RPM and continues like this.
But it will drive fine, except for when you take you foot off the throttle when it seems to jolt a little.
See this video (5 mb) to see whats happening. I am not touching the throttle at all, just twisted the key to start it.
http://www.buryhillbikers.co.uk/Video/car1.mpg
2). Once you get the revs up after sympton 1). by pressing the throttle, it will rev fine but when you let off the throttle it starts idleing at around 1200 RPM and slowely rises to  2000 ish RPM and then drops to 1800 and then rises to 2000 and cycles like this from then on.
See this video for what I mean, again I am not touching the throttle:
http://www.buryhillbikers.co.uk/Video/car2.mpg
I replaced the ECU relay 3 months ago due to a misfire issue so that is now brand new, idea's what could be causing this??????
All help greatfully received.
Ozza
Offline xxdansigxx
Standard 16v mk2
« Reply #3 on: 10 December 2006, 15:35 »
Should the car spit flames??
my m8t's got an over fuelling problem we think.
does the mk2 come with a cat as well does it need one??
thnx Dan
Offline xxdansigxx
Standard 16v mk2
« Reply #4 on: 10 December 2006, 15:35 »
thnx Dan
Offline xxdansigxx
Standard 16v mk2
« Reply #5 on: 10 December 2006, 15:36 »
thnx Dan
Offline justdone69
  • mk3 gti owner :P
my vw that iv now sold, so im dub-less :(
« Reply #6 on: 09 January 2007, 21:38 »
If It Aint Scrubbin'.... Then You Aint Dubbin'
Offline mk2_singh
1.6 to 2.0 top conversion
« Reply #7 on: 10 January 2007, 21:24 »
got a 1.6 driver that i use as a run around and im thinking of using the 2.0 8v top on it, im going to buy an engine of the bay, or parts from here.
whats the job in hand involve? iv got a weber carb on my driver already which i can use on the 2.0 8v engine right?
thanks
Offline daz123
finally fitted my new hall sender / speed sensor
« Reply #8 on: 28 January 2007, 16:20 »
well at last finally had time to work on the gti  :laugh:, wasnt as bad as i thought it would be , the old one had split at sender and the wiring was old and split , no wonder it would just cut out now and then  :sad:so after sticking jack under engine and taking the weight and loads of wd40 , and crawling under the car its sorted  :wink:
Offline dubweiser2005
MK4 Polo **STUNNER!**
« Reply #9 on: 31 January 2007, 22:14 »
Reall head turner
Polo 1.4 16v
107k
serviced regularly, passes all mots first time etc.. all documents.
Need anyinfo PM me. **NEED A QUICK SALE**
£3500.
