Author Topic: Urgent how do you change the power steering belt??  (Read 781 times)
Offline xxdansigxx
« on: 17 February 2007, 09:43 »
Right i thought i had found the adjuster but nope lol
Please help
Thnks
Breaker
Re: Urgent how do you change the power steering belt??
« Reply #1 on: 17 February 2007, 11:24 »
you need to remove the alternator belt first.
then the ps belt. i cant remember how to though. i think you have to remove one of the pulleys!
have a search something will be around
Offline xxdansigxx
« Reply #2 on: 17 February 2007, 11:41 »
no you dont there is a little adjuster on the PAS pump and a little 13mm nut on the under side of the adjuster that you need to undo lol
sorted that only out i have two belts one is too big the other too small lol
Bloody motor factors...
Offline Agreeable Slick
  • Unit
« Reply #3 on: 17 February 2007, 16:10 »
as you said, just loosen off the 13mm bolt, knock it up the adjuster and the belt will come off. There is absolutely no need to remove pulleys or take the alternator belt off. Although it is worth doing it as you are down there.
can't remember off the top of my head how long the belt is, but what ones do you have? The numbers usually refer to the length. i.e. 800 = 800mm
There should be enough adjustment on the pump to tighten it up.
