Author Topic: help Best way to remove my 16v engine from my car in a weekend  (Read 2742 times)
Offline foxy mk1
Re: help Best way to remove my 16v engine from my car in a weekend
« Reply #10 on: 17 February 2007, 08:16 »
it is easyer to keep down pipe conected 2 manifold but seperate it from middle pipe, drop the whole lot take off front panle pull it all forwards saves so much time good luck
Offline monzablue16v
« Reply #11 on: 17 February 2007, 18:20 »
I have now thanks Pegasus :)
Piccie of it looking like it's been hit by a bus! not bad at all to strip down Exhaust was a pain but all doable from above itching like a bugger from the heatwrap on the manifold :(
Offline pegasus
« Reply #12 on: 18 February 2007, 19:59 »
How did it go?
1.8 20VT GTI
« Reply #13 on: 19 February 2007, 19:05 »
Not too bad actually I was about to post pictures!!
She's out  :D  :o
piccies!
Engine out and on stand many attempts 1 moment of brilliance from Pedro
Hole in gearbox  :angry:  :unsure:
Cylinder 1 Oily :(
Cylinder 2 3 4 coked up like Docherty
Diagnosis new gearbox and Ve can rebuild it!
Offline ...joe
« Reply #14 on: 19 February 2007, 21:43 »
good stuff! its not too bad a job is it?! the re-build will be fun though, its amazing how much space an engine takes up when its in bits!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #15 on: 19 February 2007, 22:16 »
No not too bad better than I expected and only 1 dodgy nut on the gearbox that needed some dremel power! Stripping it down over this week and weekend then clean it all up and see whats what and which bits need renewing, got quite a list of bits that I want to do but see how bad other bits are first! I have boxes on standby to fill with engine!! new gasket set and head bolts to start with and then on from there!!
I just got myself an 8v gearbox which is now sat out in the garage and I'm debating whether to get it rebuilt or not!
« Reply #16 on: 22 February 2007, 22:09 »
Picture time, she's almost completely in bits now! can't get the oil cooler off as the nut is bigger than my biggest spanner, and I had to buy a Spline drive set and take the exhaust cam almost out to get the socket in! Other than that I'm getting there!!
Piston and bores look fine not sure whether to do the piston rings or not...?
Head is coked up and needs valve stem oil seals doing If I can get the bloody cams out!
Inlets look fine
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
New oil pump I think whilst I'm here, But this is the bottom
And this is how it looked when I left it! It's a sad sight!
So far so good  :)
Offline pegasus
« Reply #17 on: 23 February 2007, 10:03 »
looking good there fella...
27mm socket for the oil cooler BTW
1.8 20VT GTI
WoooHooo it's ALIVE!! few niggly things to sort tomorrow but she's running like she should :) Super Chuffed!
More pics tomorrow but heres a few :)
Offline ...joe
good work fella!!! engine looks good too, but you know i'm gonna say you should've cleaned the engine bay while you had the chance!
