Author Topic: Seat base question  (Read 1100 times)
Offline Bear
Seat base question
« on: 14 February 2007, 23:38 »
The drivers seat base section feels like its sagging, or slightly twisted (but looks fine?) is this a common problem, and is it possible to use the base section and wings from a passenger side ?
Any help appreciated
90 spec 8v
Offline ...joe
Re: Seat base question
« Reply #1 on: 15 February 2007, 11:16 »
yes its common and yes its a direct swap.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 15 February 2007, 11:52 »
joe, as you seem to be master of trimming..
my drivers seat cloth has rode up a big rib in the center of the seat and im worrid one day its gonna pull and tear.. is there anyway of pulling it flat or ironing it out or something along those lines?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline ...joe
« Reply #3 on: 15 February 2007, 12:06 »
not sure i understand, but if you take the seta cover off you will be able to iron it flat. the problem is these seats are old, the foam underneath the seat cover degrades and gets a bit sloppy and the sort of cloth 'subframe' that holds the wires, also degrades and tears meaning saggy covers!
Offline Bear
« Reply #4 on: 15 February 2007, 19:59 »
Spot on thanks. Easy job ?
Offline ...joe
« Reply #5 on: 15 February 2007, 20:11 »
yep, just seperate the top and bottom halves of the seat by taking off the plastic covers and removing the sliding clip. then go round the base of the seat un hooking the retaining wire as you go. lift off and do the same on the other side, it can be a bit fiddly removing the foam from the seat cover but nothing a bit of common sense won't cure! re-fitting is the reversal of removal, as good old haynes manuals say!
Offline Bear
« Reply #6 on: 15 February 2007, 21:03 »
Legend joe. Thanks alot
