Author Topic: Getting a SS Manifold - TO WRAP OR NOT?  (Read 887 times)
Offline xxdansigxx
« on: 13 February 2007, 22:53 »
RIght iv'e heard that if you get a stainless steel manifold you should heat wrap it due to how close it is the steering wheel rack :S
Can anyone advise this and if so what kit is best to use??
Thanks
Dan
Offline fused
Re: Getting a SS Manifold - TO WRAP OR NOT?
« Reply #1 on: 14 February 2007, 08:13 »
Not sure how correct it is, but I've wrapped mine simply because there is no heat  protection from the exhaust otherwise. I bought mine from http://www.cooltek.co.uk/ the exhaust wrap (bought the 15M but that was tight) and SS ties. Fibreglass every where!
but looks good  :grin:
Offline mk2mark
« Reply #2 on: 14 February 2007, 13:19 »
Remember with heat wrap that you're not removing any heat, so wherever the wrapping ends, that's where all your heat is going to be. Also if you leave a gap in the wrapping that's a hotspot and fires can occur, same applies for any trapped moisture. Just a warning, not saying you shouldn't do it :smiley:
sacvwgolf
« Reply #3 on: 14 February 2007, 19:23 »
there's a spray you can buy thats improves the performance of the wrap and keeps it altogether better. I used the spray on wrapped exhaust components.
Offline Dub-77
  • Dub again MK1 Golf Project
« Reply #4 on: 14 February 2007, 20:38 »
I was in the same dilemer just after christmas and went with the wrap, I bought 50ft of 2inch tape and was spot on for length cost me £50 though, /i used hose clips to secure it as we have loads at work  :wink:
So far though I have no complaints... So I would say go with the wrap.
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
