Author Topic: Acting odd after oil change  (Read 855 times)
Offline JB G60
« on: 13 February 2007, 15:01 »
Just did a oil and filter change on my 88' 8v. before I did it it it was idling fine.
now it will cut out after about 15 seconds unless I rev it. The oil level is fine and I used Castrol magnatec 10w40
Any ideas appreciated.
Jack
« Last Edit: 14 February 2007, 15:40 by ...joe »
Offline fused
Re: Acting od after oil change
« Reply #1 on: 13 February 2007, 15:17 »
That sounds odd mate, but I doubt the oil change did that! check the MK2 maintenance section for idle issues.
http://www.golfgtiforum.co.uk/index.php?topic=17309.0 is a good start and,
http://www.golfgtiforum.co.uk/index.php?topic=33253.0 by inhouse Master Tech rubjonny!!
Good luck
Offline Mr Blue
« Reply #2 on: 13 February 2007, 17:55 »
Ive had this problem on 8v's and 16v's.
adjusted the idle to suit but then it idled quite high when up to temp. Wierd one :rolleyes:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #3 on: 13 February 2007, 20:34 »
Check that your oil breather tube from the breather filter to the intake manifold is fitted correctly or that it is not damaged. Or, a silly thing, but check your filler cap is on properly!
