Author Topic: relays  (Read 1047 times)
Offline SLIM-DUB
relays
« on: 12 February 2007, 19:09 »
couldnt find a post about these so thought id do 1.
can anyone help me with a which is which on these,mine seems to have a problem and im thinking its no 67 on the top left,but what is that relay???
<br www.vwwold.co.uk<br />PIMPASAT 20v se
Mint Finish!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: relays
« Reply #1 on: 12 February 2007, 19:44 »
jonnys fusebox faq mate  :wink:
but, ive got etos open ehre atm, whats the part num on that 67, ill check for ya
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline fused
Re: relays
« Reply #2 on: 12 February 2007, 19:50 »
from haynes manual it's spot 2 which is either fuel pump realy or carb intake manifold preheating relay.
Offline SLIM-DUB
Re: relays
« Reply #3 on: 12 February 2007, 19:54 »
nice one lads, if this is knackered will it stop the car running?
part no. 857 951 253
89 96 63
thanks for the help! :wink:
Mint Finish!
Re: relays
« Reply #4 on: 12 February 2007, 20:40 »
im getting pnum cannot be determined :huh:
also you missing a fuse there?  :laugh:
John maybe this ones for you.. saying that if its a relay for carb manifold pre ehat, i dont have that on mine, and ive got the ehater under there  :huh:
Quote
Re: relays
« Reply #5 on: 12 February 2007, 20:53 »
67 = 16v & VR6 fuel pump relay, ive updated the faq :)
« Last Edit: 12 February 2007, 20:57 by rubjonny »
Offline SLIM-DUB
Re: relays
« Reply #6 on: 12 February 2007, 20:57 »
thanks jonny! is it right that under the coolant tank theres a black box with the cars main fuse in it? i think my fan housing was bent,stopping fan from moving,which then burnt out and blew something?!
Mint Finish!
Re: relays
« Reply #7 on: 12 February 2007, 20:58 »
is yours a VR6 or something? If so thats where the coolant system control relays are :)
Offline SLIM-DUB
Re: relays
« Reply #8 on: 12 February 2007, 21:02 »
nah mines a valver on weber carbs! all it did was cut everything off,noticed the fan had burnt out,which tripped something and caused everything to cut off for a split 2nd,now i have all electrice but the car will not turn over?!  :huh:
Mint Finish!
