Author Topic: I want a turbo!!!  (Read 2746 times)
Offline rocket_ronnie
Re: I want a turbo!!!
« Reply #10 on: 13 February 2007, 16:21 »
well hopefully all should go to plan  :undecided:
Offline Len
« Reply #11 on: 13 February 2007, 16:30 »
One thing you must do is lower the compression ratio.
One of the easiest ways of doing this is by fitting and extra thick head gasket.
Or perhaps machine out the combustion chambers.
www.sas.org.uk
www.the-ace.org.uk
« Reply #12 on: 13 February 2007, 16:41 »
ok so if i get an extra thick one or add 2 then i would have to torque the bolts up more wouldnt i?
Offline kniterider
  • had most, sold most and often buy more!
« Reply #13 on: 13 February 2007, 16:49 »
id get an extra thick one (1 peice) , i thinks you wanna different fuel regulator to allow more fuel through you could get a different sort that worked on boost pressure rather than vacume, so on boost she squirts more?? the 5th injector thing was onyl used on the old mechanical fuel injection/k jet?? which turbo technics did theres on?? i did a turbo technics conversion on an old xr3i many years ago, that used the 5th injector method, but i had to reduce compression ratio with a custom made head gasket to run any kind boost worthy of doing it........
« Reply #14 on: 13 February 2007, 20:43 »
ok how about i ditch the 5th injector and go for 4 x larger injectors and up the fuel pressure?
« Reply #15 on: 14 February 2007, 12:16 »
just an up date of my up and coming project.....i've found a manifold that will run a T3/T4 turbo thats a direct fit with no welds so should be good for 300bhp. I've also found a pressure switch that runs on the turbo pressure that will activate the extra injector but there both in america so there going to take a fair few weeks to get here [:^(] i've also found some 50 bhp jets for my nitrous as i dont fancy 100bhp shot and a turbo just yet lol
kieron
