Author Topic: Oil Related Problem  (Read 998 times)
Offline JB G60
Oil Related Problem
« on: 10 February 2007, 14:37 »
Checked my 88 8v for oil recently and there was basically nothing in it, it also began to sound a bit rough.  topped it up with some 10/40 semi synth and when i started it there was a rattley noise that got worse the more i revved it, took it for a quick spin and the noise just got worse and worse.
Has my engine given up??
sacvwgolf
Re: Oil Related Problem
« Reply #1 on: 10 February 2007, 14:44 »
could be the cam followers/tappets as they have be starved of lubrication
Offline mattkh
« Reply #2 on: 10 February 2007, 16:25 »
topped it up with some 10/40 semi synth nd the noise just got worse and worse.
Hi
How much oil did you put in ?
Offline JB G60
« Reply #3 on: 12 February 2007, 13:00 »
Hi
[/quote]
Roughly, about 4-5 litres there was nothing on the dipstick before i put it in.
Offline fused
« Reply #4 on: 12 February 2007, 14:08 »
Bottom to top of dipstick is 1 litre!!! You probably have put toooooo much in, check the dipstick and let some out b4 you bugger the engine up!!!! Ok might be over exaggerating but you will be putting strain on other componets??
« Last Edit: 12 February 2007, 14:10 by fused »
Offline jezza16v
« Reply #5 on: 12 February 2007, 21:36 »
Sounds teminal to me.  :sad:   If you had to put 4-5 litres in to get it to the right level on the dipstick then you've probably sha**ed the engine. It only takes 4-5 litres max so must have been empty........If your're really lucky you might just have just wrecked the top end......
