The garage
What manifold tool???
Topic: What manifold tool??? (Read 1961 times)
gti fly bye
Here all the time
VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
24 January 2004, 18:13 »
I'm in the middle of doin my head gasket on my mk2 Hreg 8v and I'm all done except for mr haynes tells me i need a special tool to remove/replace the down pipe to manifold clips? This is all thats needed now.
Is ther any other way than this tool because i'd really like to finsh the weekend so i can get the head tested and skimed monday?
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
dubslug
Re:What manifold tool???
24 January 2004, 18:18 »
can u tell me wot size spilined tool i need to take the head off??
if u got c clamps u can just push em apart, or i once heard some one heated em up and stucj a bolt between em to keep em open??
1992 pearl grey 8v
gti fly bye
Here all the time
24 January 2004, 19:11 »
Not 100% because i used one which i used a couple of years back on my 16v calibra!
I think it a 20mm
look here->
http://www.golfgtiforum.co.uk/index.php?board=2;action=display;threadid=5333
mk1
2ltr16v turbo (now with programmable EFI)
24 January 2004, 19:23 »
I remove the spring clips on the exhaust downpipe with a socket and a bolt.
Bit hard to explain, M10 bolt and nut with a washer, a socket that fits inside the clip with the nut run up to the top of the bolt, place inside the clip and "jack" the clip open by winding the nut off the bolt, forcing the clip open. Hope you understand what I am saying
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
gti fly bye
Here all the time
24 January 2004, 19:35 »
Nice one steve, so basicly the clip needs forcin apart, with you!
How will i get it back togethere thou, or will this become obvious when removed?
I'll try that first thing tomorrow!
mk1
24 January 2004, 20:02 »
When re-building, you can sometimes "ping" one clip on by forcing the down pipe over to one side. Push the pipe to the other side and refit the last "open" clip with the tool still in, on the other side. The down pipe in my opinion is the worst part of doing a head gasket on a golf
Steve.
The garage
