Author Topic: Len405 - mk3 16v  (Read 152956 times)
Offline Len
Re: Len405 - mk3 16v
« Reply #140 on: 28 April 2011, 12:58 »
New radiator was a complete and utter pain to do!
Bumper and all lights out! Crossmember off and coz I have aircon getting it out past the other rad was not easy!
Anyhow job done and all fine.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #141 on: 28 April 2011, 13:01 »
Smoothed hatch has reached an impass again!
Dont like the hump in the middle caused by the boot latch sticking up!
So will have to cut the plate off and sink the latch down in somehow!
Well I know how I'm going to do it, going to be reall fiddly!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #142 on: 28 April 2011, 13:04 »
New saga about to start!
Getting another engine to work on!
Rough plans are gas flowed head with bigger valves and new cams.
Bigger displacement, not sure how big yet.
Throttle bodies and tube exhaust manifold.
Plus an entirely new ECU system.
Not sure if I can run without a CAT yet, still chatting with ECU company about that!
Hoping to do bottom end myself, head off to somewhere.........
Then bolt on the rest! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline Neo Badness
  • Feet are for pedals
« Reply #143 on: 28 April 2011, 22:24 »
Overbore and diesel crank to 2100cc?
Sounds like a plan though...
Offline Len
« Reply #144 on: 29 April 2011, 14:19 »
Maybe even a 100mm crank and 2.30 !!!! :evil:
Not certain yet but aiming to crack 200bhp!
www.sas.org.uk
www.the-ace.org.uk
Offline Neo Badness
« Reply #145 on: 29 April 2011, 22:25 »
100mm crank, does that not restrict the rev's to 5000rpm or something? From what I gather it will be a low revving torque monster though.
Mmmmmm punchy.
Offline Len
« Reply #146 on: 04 May 2011, 21:43 »
Not sure of actual revs etc and even final spec etc. As really I am still exploring the options.
Engine bloke said about this 100mm crank and 2.3 litres so yea why not! I prefer torque to revs!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #147 on: 08 May 2011, 12:36 »
Well the 100mm crank is way too expensive so back to a diesel :sad:
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #148 on: 10 June 2011, 16:26 »
getting whole diesel engine for £150.
A brand new crank is around £365 tahts the best I was quoted.
And anyway even a brand new one would have to be balanced with the flywheel and may need some fine grinding!
So once car is pronouced fir for another year, (MOT) the engine build will start in earnest!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #149 on: 18 July 2011, 08:52 »
Engine build on back burner for now as I want to change the look.
Doing front bumper/headlights etc. as you can see in Dub Rides.
Then finish the rear hatch.
Will put selected pics in here when all done.
www.sas.org.uk
www.the-ace.org.uk
