Golf mk2
mk3 dash clocks into mk2
Topic: mk3 dash clocks into mk2 (Read 2508 times)
heinz
GTI forum regular
08 February 2007, 20:50 »
Just fitted some mk3 clocks into my 90 spec mk2 using the mk3 dash loom, the clocks power up and show the mileage, time and the tacho works but I have no warning lights, oi,l battery, handbrake, hazards? any idea why?
Cheers Si
heinz
GTI forum regular
Re: mk3 dash clocks into mk2
08 February 2007, 21:43 »
Not sure if the clocks are powering up when the ignition is turned on as there is no service indicator or mfa indication?
Dizzie
Forum addict
Make friends with your fast
08 February 2007, 23:03 »
you need to modify the wiring to run them. also what are you doing about the speedo?
have a look at
http://www.clubgtiworcs.com/modules.php?name=Forums&file=viewtopic&t=1915
for more info
Mk4 Golf 150PD
heinz
GTI forum regular
09 February 2007, 09:24 »
I am using a mk3 engine loom with speed sensor in the gearbox
heinz
GTI forum regular
09 February 2007, 16:54 »
also using the fusebox from the mk3 so I cant see a reason why I need to chop wires about?
heinz
GTI forum regular
12 February 2007, 13:27 »
Moved the wires about, its now
worse
still get the mileage and the time, when I turn the ignition on the milage flashes with no warning lights
Did the clocks differ on mk3? got 160mph ones of ebay
heinz
GTI forum regular
Reply #6 on:
21 February 2007, 21:48 »
Fixed it
there is suposed to be a shorting link between D8 and E2 on the fusebox thats the switched voltage for the clocks[
] fully working now
sacvwgolf
Guest
Reply #7 on:
21 February 2007, 22:41 »
nice any chance for pics
Golf mk2
